marty1mc »
https://forums.nicoclub.com/marty1mc-u151866.html
Tue Dec 28, 2010 4:37 am
It's not extremely difficult to change the fuel pump. It's located behind the driver's seat under the package shelf. You will have to pull the interior parts to get the shelf out, then disconnect 3 pesky hoses on the pump assembly. After that, a few 8mm bolts and it will pull out.
But, the fuel pump is quite expensive. OEM ones run around $300, new. You may want to verify the pump is the problem first. Put a pressure gauge on it and see what it is doing first.
