navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Wed Feb 18, 2004 9:55 am
your engine may be getting too much fuel because the high flow injectors can only flow so little. once you get to that point, the ecu is putting pulse at minimum length but still too much fuel getting to your engine, so it is always running rich. i may be totaly wrong on this, and if the timing changes it, then great, but if not, try adjusting fuel pressure. this is just what i have heard from various people and mechanics that i have talked to.-hope this helps you with your problem
