WD, for some reason the car didn't 'like' my wiring setup. All I did was desolder the MAF, remove the negative on the battery to reset the ECU, then resolder MAF, then rehook ECU, for some reason that 'cleared' whatever the issue was. NateDogg thanks for the advice, much easier way to check for leaks that's for sure!
Also, further progress! I got my timing light out and set the timing again to 20 degrees BTDC on the dot which brought the life back into it, then I rerouted the MAF to give it a longer run before the intake, now about 18" by using my old Injen CAI to mount the MAF to. For some reason it seems to like this setup, the car is taking accelerator now and has responsiveness again. Can't really explain that one, I know they should be at least 6" from the intake, but now it is running like a champ. It is still pig rich, but I think a SAFC will solve that problem if I need it to later on. I am going to get this thing tuned in some tomorrow on the street, then make an appointment with Passen Motorsports in Columbus to get some dyno time in for some real tuning. I will keep you guys posted on what it does and maybe post the dyno sheet if anyone would be interested in seeing the numbers? Thanks to everyone that offered aid on this scenario, it was a huge help in itself, plus made me run through things in my mind that could be adjusted and it has paid off
Two things I would ask you all to ponder on for me if you dont mind:
1. I am now getting like 40 psi on fuel pressure at idle, not 43.5 which is baseline and also what Ben at JWT mentioned. Is this going to be a problem?
2. Has anyone else seen an extremely rich condition like this with a similar setup? Also kind of confusing that it is that rich, being that the fuel pressure is down 3.5 psi. Any thoughts?
Thanks again all!!
Marc
