DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sat Sep 20, 2003 2:37 pm
A little white smoke is normal for the first few minutes (steam). After that, there shouldn't be any, unless it's real cold out. Since you're in Cali I'm guessing that's not the case. What's the smoke smell like? Abnormal white smoke is most likely either coolant or fuel fog, and each has a different smell. How does the car run? Missing cylinder(s)? How do your plugs look? If you have access to a fuel pressure gauge, hook up the gauge, start the car, and then kill the engine. The gauge will tell you if the fuel rail is depressurizing quickly...fuel leaking through or around one or more injectors.
