fuel problems as well as MAF problems
TougeTune180
Car: 1991 Nissan RPS13
so my redtop is broken again this time the car wont run the fuel pump, the relays are working, the fuse is ok, but there is no fuel getting to the cyl...i am boggled...also, my MAF quit on me, i have another, but it is a KA24DE sensor, so its 4 wire. i am under the impression that you can use that MAF if i use an Apex'i SAFC-II.....is that correct? if so, how much do you think it would cost for me to run that setup? and does anyone have any idea about my fuel problem....
Silvia007
Car: 93 Nissan 240SX SE Fastback
If all you said is working, then it's a bad pump. If it's not a bad pump, then it's bad wiring.
For the maf sensor, you are just SOL on that. Get a Sohc meter.
TougeTune180
well thats the real boggler...my pump is pretty much brand new, so i dunno, i guess then its my wiring...which is gay as aids... as far as the MAF this is the second one thats gone bad on my car in like 6 months...could there be something else that is cooking components and stuff, like really bad wiring?
