mrwonderful »
https://forums.nicoclub.com/mrwonderful-u45107.html
Thu Mar 22, 2007 1:15 pm
For some strange reason, i'm not getting proper fuel.The car died with the usual symptoms if a dead/dieing fuel pump.the relays were clicking a rather large amount. so not wanting to drop a stack of cash on an unneeded fuel pump, I got new relays. (the relays that i'm talking about are the ones labeled, EGI and EGI Pump) Dropped those in, didn't fix the problem. Pump still sounded bad and relays still clicked. So the next step was to get online and get a new pump. Walboro for 100 or stock replacement for 150.... needless to say, i went with the walboro.Just got that installed, double checked everything. Primed it a bunch of times and attempted to start the car. Nothing, the engine turned over, but no combustion. i'm thinking that it is still just air in the lines and all that jazz, so i turn the engine over for several minutes, still no combustion. I check to see if the pump is working. It sounds better than ever. I pulled the fuel line and got a rather interested result. Instead of a steady stream of fuel, it is pulsing. Last i knew, this wasn't supposed to happen. The relays are also clicking. What is causing this and how do i fix it?
