got2b240 »
https://forums.nicoclub.com/got2b240-u18026.html
Sat Jul 31, 2004 9:53 pm
im not sure if the vac lines are hooked up properly, off the manifold, the top left is going to a tee at vac gague and fpr, the one on the right is going to the BOV, on the bottom is sealed off well. I had to richen the ratio out by slightly clamping off the fuel return line after the fpr (which i replaced with used one) going to the tank. Otherwise without that the car misfires at idle and studders upon acceleration in both boosting and regular non-boost driving. I set tps to .46 volts at idle and it goes up to 4.3 at WOT. I dont get any voltage from the o2 sensor harness comming from ecu, isnt that strange...I guess i have to trace the wire going to the source tomorow. I know to test the o2 sensor you have to ohm it out, but what is the exact procedure upon doing it, what resistance am i looking for?
I have a manual POS boost controler that I had problems with before, should I try running stock boost for now to be on the safe side?
Im thinking about saving up for a Apexi Power FC, I read up on it it seems great!
