evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue May 06, 2008 7:50 pm
first of all the cam itself doesn't drive the fuel pump, there is an escentric bolted to the end of the cam along with the timing gear, I've never seen one fail, the pump on the otherhand has internal rubber diaphram that can and will rot out, simpple fix, out in a new pump and be sure the pump level correctly engages the cam escentric
as for your electric pump conversion, the SU's can only handle 2-3 psi at the needle valve, even the low pressure pumps require you to use a regulator to turn the pressure down to a level that won't overpower the needle vavles in the float bowls
do the pistons move up and down freely? any excessive movement in the throttle shafts? have you tried adjusting the jets and butterflies yet? hows the fluid? what fluid are you running?
the 260 carbs are notoriously bad and problemadict, sets of earlier roundtops can be had for $100-150 well worth it IMHO, or better yet for $500-600 you can get a set of tripples, tougher to tune but they make a lot more power
