I have had a fuel (seemingly) problem for quite some time. In the mornings she starts, but if I dont let her run for a couple minutes, if I hit the gas under load/in gear, it bogs, almost stalls, until the fuel picks up and then all is fine, until the next day. This morning for the first time she didnt want to start; finally started with some backfiring, idled but barely, and took about 5 minues before it would accept gas from the pedal. On my 120 mile run to work, it seemed to lack a little the whole trip. At higher rpms it seemed a little flat, and hesitated at take off just a tad. Got to work and just tried to start her. Fires immediately then died. Tried againand now its like shes not getting any fuel. Not starting at all. Just put 1200$ into her replacing the t belt and all related components so this is a bummer. Before I cart it off behind a tow truck thought I would get some thoughts just in case someone might have seen this before. My wife is is going to chew me out for this one
thanks yall. Appreciate any and all input
