RPS13.5 wrote:WHAT! I am confused???so how do you adjust the regulator? when the vacuum is off or on?is it34psi + 12psi boost = 46 psi fuel press with vacuumOR43psi + 12psi boost = 55 psi fuel press without vacuum
Only a NISMO FPR (or other aftermarket FPR) is adjustable. To adjust it , you idle the engine and disconnect hte vac hose from the FPR. There is a jamnut you loosen, then adjust the long screw of the FPR... Watch your fuel pressure gauge until it goes to 43.5psi (aka 3 bar). Then lock the jam nut down and reconnect the vac hose. With engine vacuum at idle the fuel pressure will drop somewhere around 37psi. That is the only time you will ever mess with the FPR....
Like mentioned before the fpr raises rail pressure at a 1:1 ratio with intake pressure...
The fuel pressure regulator is ALWAYS ran with the vac hose connected, unless you are setting it initially...
