Checkered-Member wrote:I If atmospheric pressure at sea level is 14.7PSI and the stock fuel pressure on a KA is exactly 3 times that, at 43.5PSI. So the ratio is 3:1…every 3 psi or fuel there are 1 psi of air going into the engine under NA conditions. For turbo applications if we want to keep the same A/F ratio we need a 3:1 FMU, but because we need a bit richer conditions a 4:1 will do the job. So why do people run 6:1 8:1 10:1 FMUs…?
It's been pointed out already, but it's buried in another post...
The stock 1:1 regulator is ONLY used to keep the injector flow constant...Nissan injectors are rated at 43.5psi. So a 270cc injector flows 270cc ONLY when kept at a constant 43.5psi of fuel pressure.
Under vacuum, the fuel is being sucked out of the tip of the injector (manifold vacuum), so the fuel pressure is lowered by the reg. to keep the flow static.
Same goes for under boost...with 1psi across the tip of the injector (positive manifold pressure), the fuel pressure needs to increase 1psi to keep the injector flow EXACTLY at 270cc.
Only reason we use an FPR is to keep the flow CONSTANT, no matter what vacuum or boost is in the intake manifold.
With that said...let me address one other thing:
Checkered-Member wrote:I read some technical articles and it said that to double the fuel flow I need to quadruple the fuel pressure…major ouch …FMU’s are worthless , I’m going with bigger injectors...
It's easy to figure out the flow needed to double the injector size...and I'm sure you came across it in your search(s):
[ (sq.root of (new pressure/old pressure)) x (injector size) ]
So if you went from 43.5psi to 60psi...
sq.root of (60/43.5) = ~1.17
1.17 x 270cc = ~316cc is the new size of your injector.
So to double flow (make a 270cc injector a 540cc...)...
(sq.root of (new pressure/old pressure) needs to = 2.
2 squared is 4...like you said. 4 times the pressure to double the flow.
Any fuel pressure above ~100psi should be considered dangerous, so keep to less than 100 NET (90psi base plus 10psi boost, or an 8:1 FMU at 7psi will increase pressure by 56psi (plus 43.5) is just under 100)
Anyway, I'm rambling. Sorry.
- Brian
