Fuel pressure too high, bad thing?
Structure240sx
i just got my car running yesterday with my new fuel system (jwt ecu, 740cc injectors, z32 maf) but didnt even let it warm up. today let it warm up reset the timing with the tps unplugged and checked the fuel pressure with the vaccum line off the fpr. im using an autometer underhood mechanical fuel pressure gauge. with the vaccum line off the fuel pressure is about 46-47psi at idle. with the line on its 40psi if that matters. im sure this jsut might make me run a little more rich but why is my fuel pressure a little higher than it should be? walbro high pressure pump maybe?
huguetpj
Car: 93 KAT Coupe
Structure240sx wrote:walbro high pressure pump maybe?
Could be. But the FSM says 34PSI connected, 43PSI disconnected so it ain't too bad.
Nathan
Your fpr SHOULD be able to handle the added flow of the walbro, however...it could be getting old and questionable or something. Thats really all I can think of.
95_240sx
Car: My baby (car)
Ive got a good working FPR I just took off in place of a Aeromotive unit, if you want it you can have it.
Rick
andrave
Car: 1989 Nissan 240SX Coupe
love that nico hook up
Structure240sx
i've got a whole other fuel rail with a fpr on it. whether its working properly or not i dont know. im just going to wait til hopefully early next week whne i can get my unlce's shop's wideband on my car. we'll see how it goes from there. but if the fpr is gettin old wouldnt the pressure be lower
Chezedik
Car: 1991 Nissan 240sx
That pressure is correct, you have some other problem. Are you in a 13 or 14?
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Chezedik wrote:That pressure is correct, you have some other problem. Are you in a 13 or 14?
Did you see the date on the last post in this thread...it's 18-mo old...hehe.
And I'm quite sure he has this problem worked out...the car just did ~11.2 @ 128mph.
- Brian
InsanityInc
It's a bit high.
Also, folks, a walbro 255lph WILL raise your fuel pressure, and it has nothing to do with your FPR being broken. All your FPR is is a hole in a rod that slides to expose more or less of the hole. If you flow more through the same size hole, you get more pressure in the rail. PV = nRT.
