Fuel pressure
Syrus33
Car: 1993 Nissan 240sx Hatch
RB20DET
Hey guys i got an weird issue with fuel pressure.
I'm having hesitation at WOT, Everything is stock and original on KA24DE
i changed the fuel filter(Z32) and that helped a little bit. Then I checked the fuel pressure, its 25psi at idle with vacuum connected to stock FPR.
I disconnected and capped the vacuum line to the stock FPR
Left the vacuum port on the FPR open, fuel pressure is still at 25psi.
Capped both the Vacuum line and the FPR Port, no change 25psi.
Any help would be appreciated, Thanks
neverlift
stock pressure is 43.5 wiht no vac applied to the fpr, you pump is dead or you have a bad leak.
Syrus33
RB20DET
As far as i can tell there is no leak, according to the FSM the idle pressure should be 35 and vacuum disconnected should be 43 but I'm only getting 25 in both instances, could it also be the stock FPR?
TheRealNap0le0n
Car: 1998 q45
pinch the return line and see if the pressure spikes... if it does its the FPR if it doesnt its the FP.
also could be a leaking injector or inj o ring.... see if it holds pressure after the car is shut off
Syrus33
RB20DET
thanks ill try that, and let you guys know, it did hold 20psi when the car was off.
Syrus33
RB20DET
I pinched the return line and the pressure rose about 2 psi, so I'm going to change the pump and regulator. Ordered a Walbro 255 and Megan racing regulator, should be good for a stock KA.
Syrus33
RB20DET
thanks guys issue is fixed, changed the fuel pump today, car is running 110%, pulls extremely hard.
Syrus33
RB20DET
So per my last post i had changed the fuel pump in the beginning of august, everything was working fine. A week ago i finally installed the Megan Racing FPR and after trying a bunch of different pressures, i set it at 40 on idle. The car ran great for a week but now it wont start. I have zero fuel pressure, the pump is working and i have fuel going to the rail and from the rail return to the FPR. So I'm thinking this crappy Megan FPR killed itself and that's why i have no pressure.
I also checked to make sure there are no leaks.
Does all that make sense?
If it is the FPR i think I'm going to get an Areomotive, not going to cheap out again.
