RS12Turbo »
https://forums.nicoclub.com/rs12turbo-u46243.html
Mon Nov 05, 2007 9:34 am
I've been having problems with black soot spitting out on my driveway at idle, rich smelling, and hesitation at wot at 14-15psi......all started about a month ago or so.I was thinking my oe fuel pressure regulator was crapping out from age/ walbro 255. I installed a fuel pressure gauge today in the line that goes from the fuel filter to the fuel rail. Fired up the engine, and the gauge said 30psi @ idle. I unplugged the vac line on the regulator, and went up to 38psi. When I shut off the engine, the gauge slowly started going down, and after about 10 mins, it showed like 13psi.Now, I was thinking my fuel pressure was low, because I thought I had read on here somewhere, it should be around 34psi @ idle.........but after looking at the FSM, it seems that it's actually high The FSM says it should be at 28psi at idle, and 36 psi when the vac line is unplugged.So, am I high, or low? Also, should the pressure hold when the engine is off, or is it normal for it to drop?
