DrifterProdigy85 »
https://forums.nicoclub.com/drifterprodigy85-u30257.html
Tue Jul 04, 2006 5:54 pm
it should be 43.5psi with the vacuum disconnected, and 37psi with vacuum connected. the spray pattern of the injectors are designed to work with a set amount of fuel pressure. when i lowered my fuel pressure to tune my AFR, it made the engine run rougher and didnt increase in power at all. Its best to set to 43.5psi and use the SAFCII and wideband to tune the injectors.
