420_240 »
https://forums.nicoclub.com/420-240-u12832.html
Fri Mar 25, 2005 10:17 pm
I installed my fuel pressure gauge the other day... and to my surprise, my rb was running at 72psi of fuel...
Car was running perfect... very smooth and strong pull... idle was around 750 (estimation since i don't have a correct tach)
So i turn down the pressure to 42-43psi, vaccuum off.
Car idled like sh*t for a while... died... then i started it up again and let it run for about 15 minutes and the idle returned to normal
Took the car out for a test drive after the newly adjusted fuel pressure and it feels noticeably less powerful...
The motor feels as though it's struggling then boosts... and the boost isn't as strong of a pull as it was when set to 72psi.
By struggling i mean it kind of sputters and then it begins to boost...Any thoughts on what is happening... should i turn the fuel pressure back up to where it was set?
Help as always is greatly appreciated.
