Fuel Pressure Regulator which one?
Sideways s12
Car: 84 turbo s12
Hey guys need a suggestion on a Fpr which one is everyone using? I hear the nismo one for the sr works is this true and how much do they run. Thx.
DALAZ_68
Car: 90' 240sx CA18det
nismo fpr type A...
Sideways s12
Car: 84 turbo s12
Where's a good place to buy it and about how much do they run?
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
thenismoshop.com thats the cheapest
Sideways s12
Car: 84 turbo s12
Ok so I checked them out but I didn't see anything about a gauge I take it the gauge is seperate also what do you think about an inline fpr?
sjbsuperman1425
CA18DET
the nismo one is just simple. buy that, buy a $30 gauge and then build a "T" from stuff at your local hardware store.
Sideways s12
Car: 84 turbo s12
I can get a gauge from the same place correct?
domicubarican
Car: 1989 Nissan 240SX hatchback *sold
1993 Nissan 240SX coupe
Im using a SARD fpr, works fine for me.
Sideways s12
Car: 84 turbo s12
How much? Does it come with a gauge?
domicubarican
I dont remember how much, I got it from a local garage guy I go to for parts. Well yes and no, technically they dont come with a gauge and my guy gave me one for free. Only thing bout it is that its in bar and not psi. I havent had any problems with it especially with my supra fuel pump.
Sideways s12
Car: 84 turbo s12
Ok thanks
roast
Car: 1989 Silvia
I can't keep a consistent base pressure with my SARD, don't buy it.
float_6969
I've heard from a lot of ppl, that most aftermarket FPR's can be problematic. You hardly ever hear about anything like that with OEM FPR's.
domicubarican
I've heard that SARD's are rising rate fpr's and not static like the nismo (I think that's the correct terminology). Is that true?
Sideways s12
Car: 84 turbo s12
float_6969 wrote:I've heard from a lot of ppl, that most aftermarket FPR's can be problematic. You hardly ever hear about anything like that with OEM FPR's.
Where can I find an oem adjustable fpr I'm gonna be running 1000cc injectors and I'm gonna need one
roast
Car: 1989 Silvia
domicubarican wrote:I've heard that SARD's are rising rate fpr's and not static like the nismo (I think that's the correct terminology). Is that true?
I'd set the FPR to 36.3psi (pump relay jumped), then 2 days later, check by jumping the relay and the pressure would be off.
Buddyworm
There's two different models. I'm running a SARD and it is most assuredly the static device. Very reliable fuel pressure, makes it easy to dial in the fuel curves.
Is the lock nut backing off the adjuster screw?
bersh240
my sard is perfecttt. no issues at all
Sideways s12
Car: 84 turbo s12
So sard is good? Only the static?
Buddyworm
^Yup, only the static rate. I've heard there's a few knockoffs floating around so be careful of who you buy from.
dhen
Car: MGA w/ CA18DET
If I have modest power goals and a Walbro 255 fuel pump, do I need to get an aftermarket fuel pressure regulator? I had a cheap one from eBay, and it's crapped out on me.
bersh240
yes. the stock fpr will almost always fail when using an upgraded fuel pump.
s1390
Car: 1990 240sx Silvia front end conversion ca18det swap gt2876R
Has anyone had any experience with the AEM FPR?
roast
Car: 1989 Silvia
Buddyworm wrote:I'd set the FPR to 36.3psi (pump relay jumped), then 2 days later, check by jumping the relay and the pressure would be off.
Is the lock nut backing off the adjuster screw?[/quote]
Good question, I have the FPR mounted to the strut tower, I applied enough pressure to the locking nut, I think... I've set it and locked it too many times, I don't trust the part and it'll be replaced.
cbh148
Car: 2000 Civic Si, 1993 240sx Hatch CA18
Thoughts on the Megan FPR? Seems like a reasonable price at $75 and it has a gauge. This is from FRSport, so I'd imagine it could be had for cheaper elsewhere.
A buddy of mine ran a Walbro 255 with his stock FPR and had no issues. I've got a Walbro too but hearing all you Nico guys say the stock FPR craps out with a Walbro does scare me about trusting my stock FPR.
float_6969
The stock regulator doesn't crap out with a walbro. The opening inside is too small, and at idle, and low loads, can't bypass enough fuel back to the tank and the fuel pressure goes up and the car runs too rich. Not terribly rich, but enough to cause a little rough idle, etc.
cbh148
float_6969 wrote:>The stock regulator doesn't crap out with a walbro.
>It just craps out.
mfw
Any idea if the Megan FPR is worth purchasing?
biosehnsucht
float_6969 wrote:The stock regulator doesn't crap out with a walbro. The opening inside is too small, and at idle, and low loads, can't bypass enough fuel back to the tank and the fuel pressure goes up and the car runs too rich. Not terribly rich, but enough to cause a little rough idle, etc.
When I replaced my stock pump with a Walbro 255 lph high-pressure unit, it ran rich ALL the time.
Nismo FPR solved the problem.
float_6969
Ahh, mine just ran rich as I described till I replaced the FPR.
As for the Megan, I have no experience with it, so I can't say anything about it.
biosehnsucht
Was yours the 255lph high pressure or "normal" ? I remember there being two models of 255lph Walbro pumps.
