rbsileighty »
https://forums.nicoclub.com/rbsileighty-u4927.html
Sun Feb 22, 2004 3:29 pm
Hybrid's 255L/Hr Walbro pump is pushing through the factory FPR on his RB20 and holding a nice, constant 3 bar static pressure (motor off, key in on position; and when at idle).
Wouldn't a Adj FPR only be needed if you were pushing more fuel than the stock FPR could return, or you were trying to cheat your injectors for more fuel by upping the system's static pressure? Correct me if I'm wrong, which is possible, but this is the way I understood the FPR's role. This is all overlooking the need for a race fuel system by the way, which would need them for large lines/high volume reasons.
