21FOX21 »
https://forums.nicoclub.com/21fox21-u32641.html
Sat Feb 28, 2009 6:02 am
I used a stubby screw driver, a prybar to hold and put pressure on the screw driver and pliers to turn the screw driver. WD40 helps also.
For the fuel rail just unbolt the idle air control like 3 10mm bolts and 2 hoses (try not to break the gasket when pulling it off the manifold) then just unbolt the fuel rail, pull the clips off, and change your injectors.
