SilviaSlydSydway wrote:Yeah i have a walbro 255, but dont i need a specific ratio?? like 4:1 or 7:1 or something? And i think i need it cuz i have 370cc injectors. Thanks alot, cuz i know basically nothing about fuel pressure regulators.
You're thinking of the FMU (fuel management unit), which is a regulator that spikes the fuel pressure according to boost pressure, higher than the stock fuel pressure regulator is designed to do.
If you plan on running an SAFC (or other fuel management device), you do not need the FMU.
The stock FPR is at a 1:1 ratio, which is good. This maintains the same delta P across the fuel injector, making for simple fuel tuning.
Hope that helps.
