Ok, to make a long story short, I've just gotten my sr installed by a shop and we're at the last steps of gettin the motor running. The big issue at this point is that the car is leaning out badly under boost. Or, more to the point, under WOT. Not under vacuum. I'm thinking it may be the fuel pressure regulator that may be bad. Any ideas?
Postby
S13FASTBACKSR »
https://forums.nicoclub.com/s13fastbacksr-u34823.htmlFri Sep 15, 2006 2:37 am
usually when a fpr regulator goes bad you will be running rich. of course it wouldnt hurt to try but i would also check the injectors and make sure they are opening correctly.
