I don't get it...crzycav86 wrote:The amount of boost and how much power you want will determine the ratio of the fpr. Use the pressure-flow formula to solve for the new flow, and match that to your desired power goal and duty cycle.
I'm talking about how he should select a rrfpr. I edited my post to clarify.KATwo40 wrote:I don't get it...
A 1:1 adjustable FPR only adjusts the base fuel pressure, not the ratio at which the pressure rises.
You still misunderstood...j-z wrote:actually yes it does and you even said so by saying 1:1. for every pound of air pressure, you get one one pound of fuel pressure. so if youre boosting 8 psi, youre fuel pressure will be bumped up by 8 psi at 8 psi of boost. and yes, it does adjust base pressure as well.
