Fuel Pressure Regulator
TougeTune180
Car: 1991 Nissan RPS13
my fuel pressure regulator starting leaking tremendously this week after driving my car some, and so i need to replace it, but im not sure how to get one quickly. i can order one off an early sentra se-r (93-95) with sr20de...would that work?
any advice is much appreciated, thank you
DawgMode
Car: 180sx
u should just buy a nismo adj. FPR
s13sr20chris
the ser fpr will work but i have to advise you to get a fancy one. the stock fpr can only bypass so much fuel. many people have complained that their walbro pump pushes too hard on the stock fpr. note: the 300zxTT uses a variable output type of pump(prob for just that reason). so, i reccomend getting a nismo or converting to a universal style. it also gives you a very little bit of tunability.
TougeTune180
how much does a nismo one cost and how soon can i get one? that makes sense about the walbro, cause i do use a walbro 255 pump...
SR 240Z
most of the nico sponsors can probably get you a nismo fpr, they are usually around $130 shipped or so
