mkory wrote:Not a bad deal at all.
So do we need a fuel pressure reg to run 7 pounds and not blow up?
mkory wrote:Yeah, I've got injectors, fuel pump, and SAFC, but that's it for fuel management. Do I need an upgraded FPR?
What size injectors? What kind of turbo? What is your whp goal for 7lbs of boost?
If you search, you will find the answer.
FMU's are used to push you injectors further than they support so you don't blow up.
To really know what is safe in your case... you need to get a wideband & tune / dyno tune.
There has been exact discussion about this stuff w/ mathematical formulas and all somewhere recently....
