What do you mean by trouble getting it cranked? And eventually turned over? I think with the fuel pressure regulator problem it turns over and cranks easily but wont start right away.Maybe thats what you mean. Most people say its hard to crank or wont turn over when the engine turns over really slow.Like when you have a bad battery or something.roboturner wrote:09 S hatchback with 4700 miles.
I was on a long road trip and twice had trouble getting it cranked. but it eventually it turned over, and I went on my way.
What I mean is the engine won't start. I turn the key and it makes noise but the car won't go.Versa357 wrote:What do you mean by trouble getting it cranked? And eventually turned over? I think with the fuel pressure regulator problem it turns over and cranks easily but wont start right away.Maybe thats what you mean. Most people say its hard to crank or wont turn over when the engine turns over really slow.Like when you have a bad battery or something.
Ok thats what I thought you meant. I just wasn't sure like I said before usually I think of turning the key and just hearing a click when someone says it wont turn over.roboturner wrote:
I wonder if the pump is in the same spot on the sedans because I say what I thought to be the pump in the trunk of my sedan under the carpet on the right side.Hinxy wrote: I took my versa to the dealer yesterday to diagnose my issue with starting. To clarify: It always started but, sometimes you had to crank awhile and pump gas..not what a new car should do. Anyway......It WAS the fuel pressure regulator. The have had some valve failure in a few of them and the system loses pressure. It was an easy fix as they had the part on the shelf. Diagnosed and fixed in an hour. Only the regulator needs replaced along with O ring..not the whole fuel pump. Easy access under the seat. It wasn't a serious problem that could strand you somewhere, but annoing as hell.
