Page 16, Nissan Warranty Information Booklet (Canada):
http://www.nissan.ca/owners/warranty/en/index.html
"LIMITED WARRANTY ON NISSAN REPLACEMENT PARTSTHE WARRANTY OBLIGATIONS ARE DEPENDENT UPON THE USE OFGENUINE NISSAN REPLACEMENT PARTS AND/OR NISSAN APPROVEDREPLACEMENT PARTS.What is Covered and for How LongNISSAN warrants all replacement parts supplied by NISSAN for use onNISSAN vehicles, except those listed below under “Limitations”.This warranty is for 12 months or 20,000 kilometres from the date of purchase,whichever comes first. However, the warranty on replacement parts installedin an NISSAN vehicle while it is covered by an NISSAN warranty will not endbefore the end of that warranty.Except for those items listed elsewhere under the caption “Limitations” and“What is Not Covered”.What You Must DoIn order to obtain warranty service you must deliver the warranted part or thevehicle on which the part is installed, to an authorized NISSAN dealer at yourexpense with your repair order or purchase receipt, showing the purchasedate, odometer reading and vehicle identification number. The names andaddresses of authorized NISSAN dealers are listed in telephone directories.What NISSAN Will DoParts covered by this warranty which are found to be defective, will bereplaced free of charge if the customer’s proof of purchase indicates that theitem was initially installed by an NISSAN dealer.The customer will be charged for labour if the proof of purchase indicates thatthe item was installed by other than a NISSAN dealer.LimitationsThis warranty does not cover:1. Tires or batteries. These items are covered by separate warranties.2. Normal maintenance service and parts replacement as outlined in theService and Maintenance Guide , and in section 7, Appearance and Care,in your Owner’s Manual .3. Damage or failures resulting from:• Misuse (your Owner’s Manual is your guide to proper use).• Accident.• Chemical fallout, tree sap, salt, sand, hail or other environmentalconditions, such as acid rain.• Parts used for competition purposes, i.e., racing or rallying.
LIMITED WARRANTY ON NISSAN REPLACEMENT PARTS (CONT’D)• Lack of performance of required maintenance services as outlined inyour Owner’s Manual.4. The use of replacement parts which are inferior to genuine NISSAN partsmay reduce the operational effectiveness and performance of yourNISSAN.5. Use of improper or dirty fuel, fluids or lubricants.6. Nissan Motorsports and NISMO R-tune parts, including NISMO Legacyparts are sold “AS IS” without warranties, express or implied unlessexpressly prohibited from doing so by applicable law, in which case thewarranty provided is the minimum required by law.EXTRA EXPENSESThis warranty does not cover incidental or consequential damages such as:• Loss of use of vehicle• Replacement/rental car/loaner• Inconvenience/loss of wages• Commercial lossOTHER WARRANTY TERMS AND PROVINCIAL LEGISLATIONAny implied warranty of merchantability or fitness for a particular purposeshall be limited to the duration of the warranty covering defects in vehiclecomponents other than perforation from corrosion.You may have other rights arising from provincial legislation, which willvary from province to province. Such applicable provincial legislation maynot allow limitations on the length of an implied warranty or the exclusionof incidental or consequential damages. Therefore, some of the abovelimitations or exclusions may not apply to you. "
