:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Mon Feb 09, 2004 7:59 pm
USE THE STOCK REGULATOR!
No reason for adjustable, especially with an FMU!!!
Base pressure should be stock!
Sorry to type all caps, but the stock regulator is 1:1, and responds fine to boost. The FMU will do any fuel pressure raising that's needed...
Hondas need adj FPR b/c the run a MAP sensor to determine airflow. We have a MAF, and a 1:1 reg, and it does fine adjusting to increased airflow automatically.
ANd a wordof caution...do not run 9psi with a 12:1 FMU. That's 43.5psi base pressure, then (9 X 12) 108psi on top of that...making 151.5psi pressure in the rail...NO, NO, NO!
You're just begging for a hose to plof off, spit fuel all over, and burn the car down to the ground. It's not safe...
7psi MAX with an FMU, and I would use a 8:1 disc or so...that way you keep the pressure in the rail to an more safe ~100psi...that's what I'd use for a MAXIMUM in the rail.
Trust me...rethink your setup, redo the FMU rate, lower the boost...else you'll blow the motor, or burn up the car.
Stock MAF is maxed at about 7-8psi with a T3/T04E anyway, so nine may be too much to meter...
Just food for thought...
- Brian (who's built a few (3) turbo KA setups, and blown one during the learning curve)
