livelyjay »
https://forums.nicoclub.com/livelyjay-u16717.html
Fri Apr 29, 2011 9:03 am
This is a CA16DE engine on a 1987 Nissan Pulsar SE, just FYI.
I'm still having issues with the car bogging down at low RPMs. I measured the fuel pressure and I'm reading 25psi at idle and 32psi when you pull the vacuum line from the FPR. This is low according to the manual and I should be seeing 28/36. So I ordered a new pressure regulator like the manual says. Well, I got the part, it looks nothing like the OEM regulator, and it doesn't look like you can remove the factory regulator. It has a bracket with two bolts and a hard line into the fuel rail.
Is the factory regulator replaceable? If so, how do you do it and what do you do it with?
