fuel pressure problem
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
I just installed a nismo FPR and set it to 36 psi with the vacuum hose attached which is what the fsm instructed me to do. Now my car runs like ****e! What should i check and adjust?
Rosco
Car: 91' SR'ed Hatch
Set it at 43.5 psi. Searching is your friend .
wildacexxx
Car: 2002 Q45 nav sport
why so high. isnt stock pressure 36?
da40
Car: 1995 SE 240sx
im with
C - ROD
Car: SR20DET pignose hatch
i believe the stock fuel pressure is about 43 - 45adjust it to there & let us know if it fixed the problem
pearlS13
Car: 90 240sx
stock fuel pressure is 43.5 psi (vac line disconnected).
right... 36 psi with the vac line connected... i set it originally at 43.4 psi with the vac line plugged in... =7.4 psi too much... i went back to the fsm and i had read wrong and i fixed it... i just fouled my plugs... its running fine now. Thanks guys. I think i still need to adjust my plug gap.
Rosco
Everytime I see your car in your sig, it reminds me of an FD....Glad to hear you fixed your issue IAGQ.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
You set the FPR to 43.5psi with the vacuum line disconnected from the FPR. Once its plugged in, the pressure should drop to near 36-37psi. Do not set the FPR while vacuum is connected or things will act funny.
hmm... well its acting funny now. I guess that I need to reset it.
