Fuel Pressure Issue
red coupe89
Car: 1991 Fairlady Z
2005 Nismo Frontier 6spd 4x4
2000 Honda shadow ACE 1200
hey everyone. my 91 TT is keeping me in the dark. my electronic fuel psi gauge (aeromotive) is telling me when I start the car that I have 38 psi, what it was set to. then about a minuet into idle the gauge says I loose about 1lb every 3-5 sec until I hit 0. it only shows psi when I first start the car for the day. if I turn it off for an hour or so and go back it will still show 0 at cold start up. I know the psi isint bad bc a/f is still 14.7 and the motor runs smooth, even with added rpm. don't know if theres a possibility the gauge is faulty but ive check all the wiring and the regulator (aeromotive) and cant find any flaws. don't know if anyone has had an issue similar to this one?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
I'd guarantee the gauge is bad. If the pressure would drop to 0, the car wouldn't run.
red coupe89
Post by Ace2cool » Mon Jan 19, 2015 1:06 pm
I'd guarantee the gauge is bad. If the pressure would drop to 0, the car wouldn't run..
I was starting to lean that way. maybe when the gauge heats up it starts to die? yea the car runs great that why I know there something wrong with the regulator, gauge or wiring.
thanks
Ace2cool
Probably the sending unit. Could be getting blocked by debris as well. That was the problem with my oil pressure gauge. Pull, clean, inspect, ect.
ThisIsSparTTa
Car: 91 300ZX TT 2+0
I had a similar problem with my oil sender where a piece of debris was blocking the small hole, causing a 0 reading.
red coupe89
thanks, im going to pull after work and put manual gauge on and see what I get. should tell me if its the sending unit or the gauge. ill report back with an update.
red coupe89
**update**
put the manual gauge on the line and it pegged out at 35psi (my gauge max) while the car was idling and had normal change under load. going to purchase new gauge and possibly new set up seeing as how this only lasted 2 seasons and only 3k miles. thanks every1!
Ace2cool
Not a problem! That's what we're here for! :dblthumb:
