fuel pressure is low-- 20lbs. what could be the cause
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
the fuel pump was fine when i had my ka24e. we have regrounded it. brand new everything on motor ground up. could it be z32maf or fuel pump? also if the safc 2 has not been calibrated yet could it cause it to barely run at 500rpms?
anybody please help. its def fuel related
float_6969
Did you install a new fuel filter? If so, have you replaced the stock FPR?
splintercell
i did install new z32 fuel filter, but the fpr is stock.
splintercell
i got a walboro fuel pump coming in tomorrow. the pressure was read before the fpr. hopefully this it.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Could be a blown diaphragm in the fuel pressure regulator. That wouldn't let the pressure build up.
float_6969
c-rad wrote:Could be a blown diaphragm in the fuel pressure regulator. That wouldn't let the pressure build up.
That's what I'm thinking. Replace the FPR and I'll get that fixes it.
