Fuel Pressure gauge Question
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
I am going to be installing my NISMO FPR soon, and I found an inline gauge and adapter to use from http://www.summitracing.com
gauge 60PSI: SUM-800160T for 3/8" hose: SUM-G1710
Looking at the fuel rail, you have fuel coming in that feeds the rail, at the end is the pressure regulator, which then recirculates the fuel back to the tank.
So my question is do I just hook the Fuel pressure gauge up right before the fuel rail?
That seems to make the most since to me, but I have never installed one before, so I would appreciate the help.
fito
yes, put it in after the fuel filter and before the fuel rail.
accel junky
Here's a pic of an Autometer one installed in my bay...
NISMO_RB25
Thanks guys!
goofynick6
Car: 1995 S14.5 RB20DET
http://filebox.vt.edu/users/nicolasb/DSC00644.JPG
That's my temp setup until the fuel gauge comes in...(it's an air compressor gauge..haha)
I tapped threads where the stock fpr was and put in a Tee and then have the adjustable MSD fpr after it.
NIck
BoostFab
Car: S13cp, S13fb, S14z
i used the 5/16" fuel barb fittings to 1/8" Tee adapter and mount a B&M gauge; between the filter and the rail. you can get the fittings at pepboys.
Joe
heres the only picture i have of mine
full sized - http://www.imagestation.com/pi...g.jpg
NISMO_RB25
NISMO_RB25 wrote:I am going to be installing my NISMO FPR soon, and I found an inline gauge and adapter to use from http://www.summitracing.com
So i finally got a chance today to install the gauge and fpr. I would post a pic, but it looks just like everyone else' pic. :)
Some things to note if you are doing this install:
1. You need some teflon tape when you screw the gauge into the t fitting. And you have to use a wrench to screw it in.
2. The Nismo FPR vs stock: a. The vacuum connection is down at an angle on the Nismo, so the hose will hit one of the sensors. Not a big deal, but you may need a little bit longer vacuum hose. b. The Fuel line connection is longer on the Nismo and it bends towards the valve cover. This kind of puts a binde on the fuel hose, so you may want to make a new shorter line, or shorten the one that is on there.
3. The T from summit is 3/8, but the fuel line is 5/16 so although you can make the hose fit on it, you may want to just find a T that is 5/16. (I rubbed my thumb raw getting my Goodyear fuel hose wedged on there)
4. You need two hose clamps. They sell some nice ones at Pepboys that are very similar to stock.
5. Most people I have asked said 35 with vacuum hose on and 45 with it off. a. The Nismo fpr I got was set lower than the 35/45, so you should bite the bullet and get the gauge as well. b. I couldn't get mine adjusted to that because if I set it for 35 it would only go to around 42, so I set it to 38 which lands me at 45 and said screw it.
And the final thing to remember is that if the last thing you did was install a FMIC on your car, while you listened to the radio, your battery is probably dead, as was mine :doh
JonPowell
Car: Cars, Music, My family
35 is your base PSI, you should set it there and whatever it lands at with vacuum, so be it. You gotta understand that if your idle is lower than stock, your fuel pressure will be off. If its higher it will be off.
35 Base PSI, 43 with vacuum hooked up.
NISMO_RB25
gotcha, I'll drop it down to 35.
Thanks
Wulfgang
Backwards, right Jon? Should be 43 with vacuum disconnected, and 35 with vacuum connected.
JonPowell
Good call, sorry!!!
I got all confused last night....43 is base fuel pressure, 35 is after vacuum adjustment...good thing there are good people here to double check my night time ramblings!
Damn it!
NISMO_RB25
so just so i am clear, should I adjust it to 43 with the vacuum line off, and then whatever it lands on with vacuum is fine?
JonPowell
exactly, I apologize for screwing you up....43 vacuum off, everything else is fine.
BoostFab
NISMO_RB25: After inspecting the two screws on the FPR carefully, look like it's impossible to turn it loose w/ a screw driver. Probably I will have to grid it off. How did you get those screws off on yours?
Since I have a RB20, I might have to to remove the upper intake plennum for replacing the FPR?
