Fuel pressure Gauge.
thekawaii
Car: box with 4 wheels
Is it dangerous to pur Fuel pressure Gauge inside of a car?i just figured what if line fails, gas leak thorough my car......
Autometer Mechanical Fuel pressure Gauge.
corn322
Car: 1993 240sx
yeah, I'd say it's dangerous. I'd hate to be driving then all of a sudden get squirted in the face with gasoline.
onosqv
Car: '92 240sx Vert
if you really want a fuel pressure gauge in your car, get an electronic one, that way you only run a wire into ur car from a sensor.
thekawaii
omg. then nothing is safe.
oil pressure (oil might leak)boost pressure (air might leak. I'm air alergic)Fuel pressur (fuel might leak)Volt meter (electric shocks)
slipnfall
Car: '06 D40
You can buy isolated mechanical gauges: they are required by some auto racing class(not sure if it is autox, etc). I think the way they work is the fuel pressure pushes on a pressurized diafram, which then connects to your gauge. Either that or it has some sort of safety check value that won't allow [much] fuel to flow if disconnected. I'd go with electric, but make sure it advertises good response times, so you can visually see small spikes/dips.
Silvia007
Car: 93 Nissan 240SX SE Fastback
corn322 wrote:yeah, I'd say it's dangerous. I'd hate to be driving then all of a sudden get squirted in the face with gasoline.
That's why you hook it up on the passenger side...
