Fuel pressure gauge not showing pressure? *I feel like a turd for asking this...
onosqv
Car: '92 240sx Vert
Sorry for the NEWBISH question. Ok, basically, I've been successful today at everything else: 370cc injectors, new fuel lines, nismo fpr, dsm resistor box (THANKS FIZ!), etc. On sohc 89.
However, once I start the engine, the fuel pressure gauge (which is hooked inline right after the nismo fpr) shows 0 psi. It's in about as tight as I can get my lil monkey wrench on it (2 threads still showing). Basically popped from the box, and put into the adapter.
Should I be hooking it up somewhere else? Or is there some simple step I'm missing? Using JEG's 1 & 1/2" fuel pressure gauge (100 psi) & adapter.
The car other that that runs fine... a little rich for now, but fine since I have no access to wideband yet.
onosqv
Car: '92 240sx Vert
Searching owns me...
Pressure gauge needs to be before fpr.
So that means the line I tapped into that is connected directly to the fpr is the return line?
fiznat
Car: Grown up :(
hahah yup, you were measuring the pressure of your return line. Good one!
WDRacing
Definitly not the first time I've seen that done.
