rhtuners wrote:no i did not touch the block or anything. will that is what i was thinking also that i need something to control the 370cc injectors but still i have taken them out and put back in my stock ones and it is still doning the same thing. So when i pulled my plugs they were burnt so could it be the spark. But the starts up everytime and idles fine just when i press on the gas it shuts off!?
OMFG, i thought you have something to tune for bigger injectors....when you turbo you would have to go bigger injectors and you cant just slapp on injectors and call it a day. you can blow something in an instant w/out a tune.
get an ecu tune.......that would be the best......check out
http://www.efispecialist.com i heard from many that they are very good...
there are more tuners out there but here's something to start you out with...
