96Qowner »
https://forums.nicoclub.com/96qowner-u19561.html
Wed Dec 22, 2004 6:45 am
I had many of your same symptoms, jesda. I replaced the fuel pump first, which didn't solve anything (glad I did though- it had 157,000 miles on it). Replaced the fuel filter and cleaned the MAF at the same time, and the symptoms haven't returned, but so far no sign of any trouble with the FPCM.
gniknave, mine was perfectly progressive, starting with an occasional cough at highway speed, and then later, a couple stalls when I'd completely let off the gas for exits ramps, nothing serious. Then after a few thousand more miles, more severe coughing, which then progressed to bucking and jerking. I never noticed a gas smell, but that might be because I still have a valve cover leak (waiting until I can justify a full plenum job).
Several posters had similar symptoms, and I read through all the past posts I could find. Your symptoms conform to problems with the MAF, as well as fuel delivery problems involving the fuel pump, filter, and FPCM. My experience teaches me that you should isolate the MAF first. If that's working properly, check the FPCM (which can be isolated by a jumper to ground as per jesda and others).
I don't know as much as most here, but I've been through the diagnosis of this one, step by step. 'Course, yours may be sumpin different.
