Fuel Pressure Check
DammitBobby
Car: S13 91 KA24DET
I am trying to check my fuel pressure. According to the FMU I should have at idle 34psi. My idle is showing less then 10psi. When I cut the car off it goes to 0psi. If you are running a fuel gauge what is your pressure at idle and what is it when you cut the engine off? I think my regulator is bad. This may explained why I was running lean today at the Dyno.
Nismo_Freak
Car: 89 Nissan 240SX
Bad regulator... I'd be willing to bet your car is hard to start as well.
Everyone should have 34+ psi of base idle pressure.
DammitBobby
Car: S13 91 KA24DET
Hmm now should I install a NISMO FPR or go stock? I guess I will replace the fuel pump too.
IanS13
40psi idle with walbro 255 a little to high. i hope this does not cause a problem with the 370cc injectors.
DammitBobby
Car: S13 91 KA24DET
Can I just unplug the vacuum line from the stock FPR leave it in place and install an adjustable external fuel pressure regulator? If I buy the NISMO FPR I can`t use it when I upgrade my fuel rail.
klattr1
Car: GT42R powered S14/KA
rseabrooke wrote:I am trying to check my fuel pressure. According to the FMU I should have at idle 34psi. My idle is showing less then 10psi. When I cut the car off it goes to 0psi. If you are running a fuel gauge what is your pressure at idle and what is it when you cut the engine off? I think my regulator is bad. This may explained why I was running lean today at the Dyno.
wheew. lucky your car is still running. 10 psi is bad.i hope you get it fixed soon.
Nismo_Freak
Aeromotive FPR > Nismo FPR
By alot.
MarkEmark
Car: fully-built '95 240sx KA-T
Nismo_Freak wrote:Aeromotive FPR > Nismo FPR
By alot.
True that, they look a lot better too...get one with a built in liquid fuel gauge and you'll be all set.
DammitBobby
Car: S13 91 KA24DET
Do I have to remove the old stock FPR??
DammitBobby
Car: S13 91 KA24DET
Ok figured out what the problem with low PSI readings. I had the gauge on the return line not the pressure line. SOMEBODY SLAP ME SILLY!!
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
we'll let you slide this time, but only because you are guinne pigging the boostdesigns kit for us
