what size do i need the Barb fittings to be?sjbsuperman1425 wrote:go to home depot, Lowes, or equivalent and get a Brass T with 1/8" ports and two hose barb fittings to put on the sides. Use thread sealant on all threads and install pressure sensor.
what do you thinksjbsuperman1425 wrote:go to home depot, Lowes, or equivalent and get a Brass T with 1/8" ports and two hose barb fittings to put on the sides. Use thread sealant on all threads and install pressure sensor.
zmannz wrote:I bought a high pressure gauge and the "T" adapter in a package at advance auto parts a while back. The t part was brass and the whole deal cost about 20 bucks.The gauge was crap the first time so I took it back and swapped, good to go now!
sooo... theres a 15.00 $ f***ing minimum...btm88 wrote:Yes, the fittings you have listed will work great. I have the same things for my fuel pressure sender.
lol i figured corrosion would be an issue at some point...lolmeminto wrote:Yep that will work fine, the only issue is if your male fitting is alloy, it will suffer from corrosion quicker as result of the chemical reaction between the two metals..
But I am talking years here lol...
I forgot to add, make sure your reg is plumbed in to the left of the hose in your diagram..
Modified by meminto at 2:14 AM 12/18/2009
yeah thats what i was planning to do...sjbsuperman1425 wrote:http://viewmorepics.myspace.co...89782
that is how you want it. i should've just posted that a long time ago lol
meminto wrote:Measure yours to make 100% sure, the detail in the diagram is all aftermarket, it was more to give you an idea of the position of the reg in relation to the flow direction of the fuel..
My lines are 3/8" aluminium, my stock fuel lines had a smaller ID...
Best bet is to measure the ID of your lines and send the details off to the company if your buying online, or take the line with you if your going into a shop..
1/4" ID hose sounds close to what was stock on mine..
RS12Turbo wrote:I got all of my parts at Ace Hardware and Home Depot, and the gauge from Summit.Just go to these 2 stores and piece it all together...it's a no brainer really.
