Fuel/Power problem
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
check engine light is on for Fuel Injector leakcar will run about 80% of the time with full poweronce in a while the CEL will blink as if a sensor is loose or something and power will drop.. during this time car is running rich and small blips/backfires can be heard.
new plugsnew wiresnew fuel filter2 new injectors
many say the code is too general and could be ur fuel pump or pressure regulator acting uphow do i go about finding which is really the problem?
xorro
Car: 92 nissan 240sx convertible
check your fuel pressure wit a pressure gauge it should read more then 32 psi. anything less means your fuel system is in stress and check your coil for proper spark use a ohm meter to check it and wires
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
so its blinking off then back on when its running bad, but otherwise on, right? id fix that problem before i tried to troubleshoot other issues.
S3t0_S13
srpowered240sx wrote:so its blinking off then back on when its running bad, but otherwise on, right? id fix that problem before i tried to troubleshoot other issues.
yeai just dont necessarily know how to diagnose the problemi can go a week without seeing itthen sometimes it blinks without any pattern and im still at full powerthen it randomly cuts off for like a day or 2 with those symptoms
xorro wrote:check your fuel pressure wit a pressure gauge check your coil for proper spark use a ohm meter to check it and wires
there a write-up on this anywhere?
S3t0_S13
k picked up a ohm meter 2day will check sparks
