yann_S13 wrote:would a block fuel line make the fuel pomp fuse burn??
No.
Most likely, a fuse burns due to age, a large spike in current or a short.
Check your voltage to the pump.
Turn ignition key. You should hear the pump activate.
If you hear pump activate, turn ingntion key back to off.
Go check your fuel lines.
make sure you have them correctly installed.
I have installed my fuel lines backwards before
If you do not hear your pump activate when turning key, then you more than likely have an electrical problem
