Ditto.yodawill2000 wrote:93 for me ..
FYI, the knock sensor isnt just there for people who dont want to use 93. Its there to prevent failure of the engine.atlanta_shooter wrote:Use 87 or 89 or 93. Infiniti made a big deal out of posting "Unleaded Premium Fuel Only" all over the car, to scare the crap out of you ...as long as knock sensor is operating properly there is no harm done to the vehicle whatsoever. You will lose a little power, but probaly won't notice unless at WOT. When I have run lower octanes, I have noticed no decrease in MPG. All new Nissan/Infiniti with even higher compression engines state that 91 or higher is "recommended". Bottom line is, yes, car should perform at peak with 91 or higher, but don't sweat it.
This engine was deisgned for high compression, with high compression you must use higher octane. Simple as that.
Gas stations underrate their gasoline. Due to the simple fact that if a lower than advertised octane is found there is a huge fine involved, and I believe they station is required to remove the tanks for inspection.robmcole wrote:I get the best gas mileage on 89 octane. It isnt the price b/c if you do the math, its about $1.00 more to use 93, but I get 2-3 more MPG on 89 octane.
-Rob
