xsvhp wrote:Your ECU is probably allowing the timing to be advanced because it is not sensing detonation. In some cases, this slight advance in ignition timing is conducive to better mpg AND power.
Pretty rare, but I've seen it happen on some cars which are set at the factory to allow as much timing advance as possible.
The B15 Sentra SE-R has a similar QR25DE motor to the Rogue and was quite sensitive to engine knock/detonation. It would pull timing on a whim it seems. That motor also had a fairly aggressive timing curve unlike the same QR25DE motor used in the Altima. I tried regular and premium fuel in my '03 Alty with the QR. I never got any better fuel economy. I expect the Rogue to be the same in this regard although I have not tried it.
I think jhrain's increase in fuel economy is more attributed to other factors:
- driving habits- the engine is breaking in. I saw a stready increase in fuel economy after the first tank in fuel. I went from 22 mpg when new to 28 with over 7000mi on the odo.
