fuel needle is wrong
nyc_ink
Car: 2001 pathfinder
I noticed last month when I topped off that my fuel needle didn't go up to full and after a week of driving it randomly moves. I've been calculating my milage every time I pump gas. I calculate 14 mpg city x amount of gas I put in.
Has anyone had this issue? How did you fix it?
atraudes
Car: 2001.5 Infiniti QX4 4WD
The most likely suspect is your fuel float is either sticking or starting to go bad and send bad signals. Check out page EL-126 in the FSM for troubleshooting steps to confirm where the problem is. If it's sticking you may be able to simply give it a good brushing/cleaning and get the movement smoothed out instead of buying a new one.
You can reference spike753's guide on replacing the fuel pump to see how to get to what you're interested in.
Good luck! :bigthumb:
nyc_ink
thank you bro you're the man.
I'll just replace it to avoid future bad signals lol and while i have p1140 code i can't notice the gas going down lol
atraudes
:dblthumb:
I'd highly recommend following the troubleshooting steps before you do. I'd hate to see you spend the time and dime on a new unit to find out it was something else :cry:
nyc_ink
atraudes wrote::dblthumb:
this weekend im going to take out the float assembly from under the back seat and brush it clean and hopefully loosen up the arm and it gets fixed.
