fuel mileage
shortdogg1980
Car: 2001 infiniti i30t
what are some of you getting as far as fuel mileage? on my 2001 i30t i'm averaging 19mpg on mostly highway driving.
maxhopper
Car: 02 Maxima SE 6spd
I average about 15mpg city, and between 25-30mpg highway (3.0/automatic).
shortdogg1980
i couldnt get that good of mileage even if i pushed the damn car, i have heared numerous bullentins about the knock sensor going bad and retarding the timing and affecting fuel mileage, but its what its supose to be at warm idle, 15 degrees, have u had problems before wit bad fuel mileage?
maxhopper
Go to your local Autozone (http://www.superpages.com/b2b/N-AutoZone/S-NC/) and have your codes read. If you get a code for the knock sensor, you will know.
My highway mpg is based on long trips with the cruise control set.
The 19mpg you are getting for mixed driving doesn't seem that bad. How long are you on the hwy .vs city streets and on/off ramps?
shortdogg1980
i have my own scan tool(snap-on modis) i have no current or pending codes, all my data looks good, fuel trims,maf,timing,etc, is all good, i dont know my mileage sucks so bad.
NissanDriver84
Car: 1997 Nissan Maxima
My mothers 2003 Maxima averages 27.5 MPG mixed city/hwy my 2003 I35 averages 25.6 MPG mixed city/hwy....
Cressida
I have been considering buying a I30 A33 and after reading this I might as well keep driving the old Cressida. How about some more I30 owners reporting in.
I thought around 20mpg in town and 28-30 on the open highway. Is this possible or just a pipe dream. Also the I30's need 89 or 91 octane gasoline (mid or prem grade) for best performance is that correct?
rxm6
Car: '93 240sx
I30's really want 94, but they don't have that around here, so I'm stuck with 91, which isn't too big a deal. Infiniti recommends 91 as a minimum for proper performance and mpg. Anyway, my knock sensor went bad and I was getting about 18-20 mpg average. So what I did was ordered a new one and, for the time being, put a few resistors on the end of the KS plug to emulate a good KS switch for the ECU. Subsequently, my mpg average jumped to about 23-24 mpg average. This is with a short ram intake which is sucking in hotter air. So, I would imagine I might get 24-26 mpg average with a stock setup.
00MaxSE
Car: 2000 Nissan Maxima SE 5MT
25-26 mixed driving on my last fill up.
Ryan Heo
Car: 1996 Infiniti I30
96' infiniti i30 124k...16gal with fuel injector-> 250miles... huh...15.625 miles/galPlease help me...
maxhopper
What octane gas are you running?
rxm6
Car: '93 240sx
Ryan Heo wrote:96' infiniti i30 124k...16gal with fuel injector-> 250miles... huh...15.625 miles/galPlease help me...
Dear god....
(Where else would you use a bunny with a pancake on its head?)
Ryan Heo
I used to filled Extra grade oct. 89 up (I'm not sure).I'm very frustrated... huh...Can Anybody help me???
maxhopper
I suspect that if you are not using premium, then you are probably getting some knocking. The knock sensor compensates for this by retarding the timing. Therefore, your engine is not at it's most efficient, and you are getting crappy mileage.
MattB
Car: 2001 Infiniti I30A
In mixed city and highway driving (mostly stop and go on the highway too), I got about 25mpg out of my last tank. Driving home to Boston from Virginia last month I saw 31mpg from all highway driving. I always use 93 octane fuel (or 94 if it's available) Interestingly my gas mileage has gone up by about 2mpg since I switched over to full synthetic oil.
Ryan Heo
I will fill it up by premium.However the premium gas is octane 91 in Michigan.Is it enough?Do I have to put some octane booster?Thanks
shortdogg1980
everyone that i have read posts about on there infiniti's wit bad fuel mileage are all owners of i30t, i'm just curious as too why, i use preminum gas, the car runs fine timing is dead at 15 degrees, i dont know what else to do wit this gas guzzler, i cant afford to drive it everyday at 17.5 mpg.
Ryan Heo
You got 17.5 mph per gal.You are lucky man...Even my car is not touring but it has only 15mph per gal.I really really need help...Thanks.
rxm6
Car: '93 240sx
You guys need to pull your codes if you are getting anything less than 24 mpg out of an I30t running 91 octane. t stands for touring. It has stiffer springs, a spoiler, heated seats, auto-dim mirror etc. This has nothing at all to do with the motor. The motor is a VQ30de used in all 4th gen maximas and i30s. There is no difference except for the VLSD which would not affect MPG.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I'm curious, what do all of you think the capacity of your gas tank is?
When I first bought my 96 I30, I thought it was about 15 gallons, research and testing lead me to find that it's closer to 18 gallons. I've been able to drive my car to a complete stall (emptying out the gas tank for the most part) and when I filled up, the pump read 17.59 gallons. Online specs say 18.5.
Are all of you guys accounting for that capacity or are you using an offset method in which you fill up every time to find out how much you've actually used?
My mileage varies between 16MPGs during the summer with a dirty short ram in the city, up to about 24.5 MPGs in cooler temps with a clean filter on the HWY.
I'm perplexed by anybody who reports over 26MPG because that was the EPA estimate for the 4th gens.
shortdogg1980
once again i have no current or pending codes of any sorts, my timing is 15 degrees at idle, fuel trims are excellent, it runs great, im wondering if i should just change out the knock sensor for the hell of it ( i really hate to pull that upper intake), but i dont no any other way to go....
Ryan Heo
You don't need to pull intake up for replacing knock sensor.I did today without taking intake things off. It just spent less than 30min but the sensor is horrible price.
rxm6
Car: '93 240sx
Ryan Heo wrote:...but the sensor is horrible price.
I bought mine for $65 last week.
Daddygonz
Car: 2010 Ford Mustang GT
04 Infiniti G35 coupe
04 Roush Focus
02 Infiniti I35
94 Chevy S10 PU
91 Volkswagen Golf GTI Mk2 16V
90 Camry
86 Nissan 300ZX
I drove my 02 I35 down to Maxwell AFB (75 miles) today and at 75-80 mph the computer was reading 25 mpg. I went there and back with A/C running on high with wife and two kids. And I used less than a 1/4 tank. I am running Premium Unleaded and my car has 43,000 miles.
shortdogg1980
i changed my knock sensor on my 99 maxima without r&r upper intake, but the intake on my i30 is different, i cant get to it without removing the intake.
bigtisas
You may need a new oxygen sensor. Usually bad mileage is related to that.
Ryan Heo
I got three O2 sensors today.All of them is NTK.I will tell you guys after replaced.Thanks.
derjimmer
I'm averaging 22 in town, 30 on the highway. My 2001 I30 has 50,000 miles on it. I bought it new. I've used 89 octane in it for the past 4 years, with no knocking.....runs great!
shortdogg1980
i replace one cat converter and all the o2 sensors, i've spent a ton of cash on this thing, but i'm done worrying bout it, i sold the car this past week, i'm gonna let it be someone else worry.
