Ace2cool wrote:Oh. Yeah. That's gonna be a hard one to find a good shop near. And the cost of shipping a car to SZ is gonna be ballpark of $2K. Hm. I'd say Z1 would be closer, but if you're going that far, then SZ is the better option by far. I don't really know anything north of the mason-dixon line, though.
This guy that Seb recommended in Nebraska sounds really good. I've been chatting with him and he knows what he's about. The Branson Z Fest is coming up and he is very busy right now, then when he gets back from Branson he has a an aftermarket mid pipe and Cobb retune on a 2011 GTR, then he'll be able to get me in.
So that will give me time to save up for the other mods he recommened for me... he asked if I wanted him to do the coolant bypass from the throttlebodies (I said "sure"). He wanted to know if the intake had ever been pulled before? ( I don't know what he means by this)..
This is the first part of his message:
Yes I am qualified to do everything you have listed and honestly the hardest part will be installing the new harness in the thick firewall... well... "wall". In terms of adding VTCs I believe the 96' heads have accommodations for them to bolt on but that is a Seb question. It's funny I just had the conversation earlier today on why not to buy a 1996. LOL! The OBDII stuff really scares everyone off I think it's cool you are doing it.
For my goals he suggested the JWT 530's instead of the JWT 700's..
The JWT700s are kind of overkill to make 500-550 WHP yes they will do it however a smaller turbo like a JWT530 or GT600 from Z1 would be plenty and probably less lag so more low end spool up. I probably wouldn't suggest doing the MS Manifolds yet unless you are upgrading turbos though just from a cost savings aspect. You have to pull the turbos off to change the manifold...so you might as well bolt bigger ones on at the same time. You also can't run bigger turbos without larger injectors.
So he suggested I get:
2.5" intercooler plumbing, Ash massives, and larger throttle bodies can all be done without upgrading the turbos especially since the stock 2" is even inefficient on stock T25 turbos. The Stillen intercoolers will help some but the larger 2 and 1/2" stuff is a leap by comparison power wise.
The stock fuel pump is good for over 600WHP so you should be good for awhile unless you just want to be preventative and and put in a new stock one down the road. I am just under 700WHP (on race gas) and now I am upgrading to a second fuel pump to push onto 800+WHP.
The good news is you have the 95+ fuel rail and newer style injector clips so all you will need is 740cc injectors and new OEM o-rings. (These I would definitely do now if budget allows especially since you are getting an ECU with a socketed Eprom...they can put the new tune in now for the injectors.
He told me that since he'll have to pull the engine, his base price is $1000 and we'll go from there. In all honesty, I think he will be cheaper then the local performance shop and will do much better work. Shipping from Kansas to Nebraska is also very attractive.. IMO, the fact that Seb recommended him says a lot.
EDIT: Tell me what you guys think, I think he sounds like knows what he's doing. But then again, I don't know anything about cars and it would be really easy to BS me, did he say anything that sounds questionable or just plain bad advice??
