C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed May 14, 2003 8:26 am
This post is a bit confusing. Either some of you are using the wrong terminology or are mistaken about what the items you are describing really are.
FPR is just a fuel pressure regulator. It can be stock, Aftermarket adjustable 1:1 Aftermarket x:1, or Aftermarket Adjustable x:1. The term isn't specific.
An adjustable FPR allows you to adjust the base fuel pressure, but still rises at a 1:1 rate.
A Rising rate FPR refers to a boost dependent FPR or FMU.
As far as which one is best to use or if at all depends on your preferences. A rising rate FPR is a cheap way to get more fuel when boosting. *To Rick* - I wonder if you've even tried using one. For the cost, nothing beats it. It of course has limitations, but within those limits, it works great.
An adjustable 1:1 FPR can be used to feed more fuel, but requires retuning the ECU or running a piggy back. You can certainly run a high fuel pressure so that the fuel requirements are met under full boost, but since the fuel pressure is fixed, it will run very rich at all other times.*Sil240:* Stock FPR's also rise at a rate of 1:1. Actually, any 1:1 regulator will regulate pressure in reference to manifold pressure so that it is always a certain set psi over the manifold pressure.
Rising rate FPR is what you use to surpass the stock injector's rated max flow rate. Since it increases fuel pressure more as you get more boost. Most people and kits use a 7:1 or 8:1 RRFPR which is good for up to about 6-7 psi.
Lastly, to answer Wakkolio's question, it depends. If you are using stock injectors, then yes. An AFC or E-Manage will not give you more maximum fuel if you are already maxing it out. With larger injectors that are sufficient for the boost level you are running, no, you won't need a RRFPR.
