fuel management???
LADrifter
Just so you know I already did a search and it helped a little but I want to futher narrow my research into this project. I want to know about three to five good options for fuel management. I want to get 400to 450HP at the wheels? Please include approximate cost, the amount you can tune the system and also a good size injector for a daily driver running high HP. Thanx for your time
93semax
555cc injectors- Tomei,blitz ~140x6= 640SAFC ~300Walbro HF pump ~ 110 ----------555cc injectors 640PowerFC w/HC 1200Bosch FP 300Fuel PressureReg ~200
I will be going with the PFC and 740cc tomei injectors.
WDRacing
What engine??
Vrtgrumpy
I would also upgrade the MAF to a Z32, along with what 93semax said. And don't forget to change to a GOOD clutch. I am running a OS Giken, not to good for traffic but it holds everything I can give it. TOO noisy though..........
Grumpy
LADrifter
oh my fault its the RB25
cyris3d
whats the diff from the z32 maf and the rb25 maf??... they look pretty much the same diameter
anyone know of replacement injectors(550s) for the 25?.. i know the rb20 uses rx7..
FAST-DATSUN
Z32 flow higher # and can make more HP before maxing out..
wcbjr
Car: KA24E / hatch
cyris3d wrote:anyone know of replacement injectors(550s) for the 25?.. i know the rb20 uses rx7..
Whatever the SR20's use.
Side feed, high impendence
http://www.meggala.com/injectorscss.htm
Here's a url for some big ones: http://cgi.ebay.com/ws/eBayISA...32094
Nismo_Freak
Car: 89 Nissan 240SX
93semax wrote:555cc injectors- Tomei,blitz ~140x6= 640SAFC ~300Walbro HF pump ~ 110 ----------555cc injectors 640PowerFC w/HC 1200Bosch FP 300Fuel PressureReg ~200
140 x 6 doesn't equal 640 LOL
840 sounds more like it.
Bryson
Car: 93 240sx Hatchback /w Sr20
I just bought an Emanage /w support tool and injector harness to control my fuel management. The emanage is made to work with most Jap engines and the RB25 is listed. Nobody knows yet how well they work. It is an option, I'll let you know how mine goes.. PENDING I EVER GET AN ENGINE!
wcbjr
Car: KA24E / hatch
All the RB-T motors are listed as compatible. :)
Bryson
yup. sorry I shoulda stated that, I was just stating its use for my particular need.
