fuel management system?
Rs4racer
anybody know any manufactures of these? you know what i mean the laptop and all to get rid of the ecu and maf and all.thx
Daunttless
haltech is a fairly "common" one.
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
anyone heard anything about Apex'i Power FC? Can you control more than haltechs?
-Andre
Daunttless
the apexi power fc is a piggy back, not as versatile as the haltech which is a full stand alone, and its hard as hell to tune. : )
Nismo_Freak
Car: 89 Nissan 240SX
Haltech, Motec... these are standalone systems and will require you to find a good base map for the car. From the base map you dyno tune the car by adjusting points and running it on a dyno for power and a A/F read-out.
ST240
is it worth buying an Power FC?
Nismo_Freak
Well.. honestly if you know a bit about proper fuel tuning then it would but honestly I think the Apexi AFC will suffice.
I H8 UR DSM
i dont think the Power FC is considered a 'piggy back'. It does fully replace your stock ecu, therefor i dont think its refered to as a piggy back.....
sickboy
the PFC is basically a factory ecu that gives u control over the ignition timing and fueling parameters, along with giving you sensor information.
the haltech E6K, gives you control over basically everything, with way more programable outputs than the average user will EVER take advantage of, i.e antilag (turbo-killer), etc. also the E6K isnt a b**** to tune really.......assuming u have access to a wideband its fairly user friendly. just manipulating bar graphs
the other option id look into for standalone EFI would be a F.A.S.T system. not cheap........but VERY user friendly, and VERY capable. from what little experience ive had with the FAST, im considering putting one on my next project if i dont use my haltech
