Fuel management options for our G's
WESIDE
Car: 2006 g35 coupe
I have been running lean for a long time with the mods I currently have. Any suggestions out there for a ecu piggyback that is not that pricy?WesIde
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
Why do you want a piggy back? What are you trying to do?
Split Second makes a piggy backSo does ARC
Jacko3
weside:
How do you know that you are running lean? I ask becasue I have similar modes as you and it could be that I too are running lean as well, since I get good gas mileage with my G-35 Coupe. I also have one heck of a lead foot too!
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Jacko, you're so funny. The rest of us are complaining about fuel economy while you are putting down more power and getting better fuel economy and you're wondering if you're running lean
WESIDE
Car: 2006 g35 coupe
I know that I am running lean on one bank due to the discoloration on the exhaust. I can only figure that with the right fuel/air mixture at full throttle vrs highway cruising I could be loosing quite a bit of horspower due to the fuel mixture. Also note I do have spark plug non foulers on my o2 sensors and I think that could be one of my issues. I still think under my circumstances that some kind of fuel management system would improve my performance greatly.
gwoods
You need to dyno your car to see if you are running lean.
On my Hemi I ran a wide band AF gauge, sometimes I got as high as 15 but thats not too bad. WOT dropped to 12.5 and slowly climbed to about 13.2 before the shift to the next gear.
In my experience piggybacks can add more problems then they solve. I would be real sure you are running lean and that bigger injectors are not a solution before you start manually adjusting fuel trim values on MAP or whatever sensor the piggyback 'adjusts'.
I didn't see cam's or any other internal engine mods on your list of mods? It is real unlikely you are running lean enough to be a problem unless you have some serious mods.
Have you ever had a CEL that was "lean bank one"? Your ECU will let you know if you are running lean. Its been over a year but I think the code was 0171. I only saw that code a few times when I ran open headers at the track with none of the o2 sensors connected.
I saw 0440 about twice a week and 0420 about once a month.... I did the anti fouler trick too. to the person that figured that mod out!
WESIDE
Car: 2006 g35 coupe
Thanks for the input woods. I will greatly consider getting it on the dyno. I am happy with the mpg. About 20 a gallon but I need more power. Maybe F. I. is the only next option. Any other considerations on this would be great. Thanks a bunch.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
what is this talk of anti foulers?
I'm not familiar with it...
TeflonG35
Car: 2003 G35 Sedan
About being lean.
http://www.alteredatmosphere.c...=350Z
joe603
Car: 2014 Durango R/T
Most are not cheap. Greddy eManage and UTech are 2...but those are for FI apps usually.
WESIDE
Car: 2006 g35 coupe
Has anyone here done the AAM ecu reflash and if so what did you think?
WESIDE
Car: 2006 g35 coupe
I was also wondering how much a new ECU would run me.
