rseabrooke wrote:I am running the BD Stage I kit with the 12:1 FMU, walbro 255 and boosting at 10 PSI with the help of a MBC.
Please, for the sake of not providing wrong advice, can you test your FMU to see what is really happening? Check your base fuel pressure with the vac line off the factory FPR and the FMU (plug them so you dont have a vac leak) and your motor running at idle. Use your Mitivac to put pressure on the FMU one psi at a time and see how much it goes up for every psi. If the first psi of pressure you put on the FMU nets you 12 psi, and then again on the second psi, then the FMU is 12:1 Eventually, your fuel pressure will not go up any further no matter how much boost you put to the FMU. This is the pressure limit for the pump minus what the injectors are bleeing off. You will find that at WOT where your injectors are bleeding off more fuel pressure, the peak fuel pressure you can make will be less.
IMO a 12:1 FMU is WAY too much. 4:1 or 6:1 would be much more reasonable for your application (not that I recomend FMUs) and would work better for your target boost with the fuel pump your using. The way your running it now (if you really do have a 12:1 FMU) at 4 psi, you will have 93 psi fuel pressure. I believe I read in one of your posts, you maxed out at 100 psi? If that the case, then your fueling is the same from 4 psi to 10 psi and will probably be the same for your intended 12 psi. With a 4:1 FMU, at 4 psi, your pressure would be 61 psi, 5 would be 65, 6 would be 69, 7 would be 73.... etc etc.. Obviously, this setup would have to be verified to work well on a dyno with a WB O2 sensor.
I believe you also stated that your AF was extreamly rich. With the lower rate of gain FMU, this would certainly help at lower boost levels. The load on your injectors and pump would also be less. And as you should know, as fuel pressure goes up, the ability of the pump to be able to flow fuel goes down. At some point, your risking going lean and melting your motor from lack of flow from too much FP.
